Hey. I just bought a 1300C and I love it. However, I've got a tight fit with my toe between the peg and shifter. It looks like I can adjust it but I don't know what to adjust. Anyone wanna help? Thanks in advance.
I have not had mine off but most bike have a splined shaft here. Some you can remove the lever and walk it around the spline. It is not the best way since doing this will change the leverage needed for smooth shifting. Some shift levers can also be moved on the shaft if it is also splined but doing this will still require the linkage to be readjusted.Thanks for all the great info. I think it will come in handy. One more thing, someone told me that the gear shifter can be adjusted by manipulating the rod located under the engine and is attached to the gear shifter. Anyone know about this? Thanks.
