81 - 100 of 107 Posts
Ok, I changed out my coolant Saturday, so I thought I would go ahead and take some pics along the way.
The bike doesn't need to be on a stand, but it makes things easier to get at.
First thing is to remove the tank. Check out Bassdudes link here. http://www.vtxcafe.com/showthread.php?t=33679&highlight=tank+removal
Then remove the radiator cap.
Remove the left side cover, and left side trans cover.
With a pan under the bike to catch the fluid, remove the cooling system drain bolt, and allow coolant to drain completely.
Reinstall the drain bolt with a new sealing washer.
The manual calls for removing the siphon hose from the overflow tank and draining, but I chose to remove the entire tank and drain and clean. You only have to remove the filler neck, and one mounting bolt. There is a rubber grommet that holds the right side of the tank so don’t lose it.
Pull the tank down as far as possible and then remove the siphon hose and hold your thumb over the inlet while removing it the rest of the way.
Clean and reinstall the overflow tank.
Fill the system with a 1:1 mixture of silicate free ethylene glycol anti-freeze and distilled water up to the filler neck.
Set the tank back on and connect the fuel and vacuum lines and run the bike at idle for 3 minutes. Give the throttle a few rev’s to work any air out of the system.
Top off the coolant at the filler neck, and replace cap.
Fill the overflow tank to the high mark (I used a squeeze bottle and filled it before reinstalling the filler neck) and replace cap.
Wipe everything down, check for leaks, replace side covers and you are ready to roll. :choppersm
If I missed anything or anyone has anything to add feel free.
I cant see the pics
Look at Post #53...all of the pictures were reposted there and they are currently visible.
The pictures are very helpful!
i did a video of it here:
Photophucket screwed many who had pics posted there. This is why the content is missing.
Reactions: mjklaser
I just squeeze the suction hose (bottom raditor hose to waterpump) numeroud times to remove air in lieu of cranking and burping. :patriot:
:icon_suspicious:
Reactions: mjklaser
Here is a good link that describes how to do a flush and fill correctly for those that haven't done it in a while or want to do it. This post is just a drain and replace which most people do. Its on a cbr 1000 but the process is similar for all bikes. Hope this helps
https://www.russbrooks.com/2009/4/5/flush-the-cooling-system-on-a-honda-cbr-1000rr
Well, nevermind. It doesnt seem to want to go to the link from this forum. But, if you go to russbrooks.com and click on motorbikes on the right under categories you'll see it. Maybe cause it's not a secure site? But, ive never had a problem with it
Updating this because I do it "differently" and I still can't see the pics:swear:
First thing is to remove the tank. Check out Bassdudes link here. https://www.vtxcafe.com/showthread.ph...t=tank+removal
I remove the instrument panel, rather than unplug the dash.
Remove the left side cover and leave the transmission cover alone.
With a pan under the bike to catch the fluid, find the lower radiator hose and loosen the hose clamp. Remove the hose, and allow coolant to drain completely.
I got crazy, and connected the exhaust side of my Shop Vac to the Radiator Fill (where the Radiator Cap was) and blew out about a cup of coolant that was hiding in there somewhere.
Reinstall the radiator hose.
The manual calls for removing the siphon hose from the recovery tank and draining, but I chose to connect a ÂĽ" hose to the tube that connects to the coolant recovery tank at the radiator cap, and used the Shop Vac to start a siphon of the coolant out of the tank. I got about another 2 cups of liquid...
Clean up the recovery hose. I had to cut off about ½" of cracked tube. and reinstall the hose that connects to the fitting where the radiator cap goes..
Fill the system with a 1:1 mixture of silicate free ethylene glycol anti-freeze and distilled water up to the filler neck. I used Toyota Long Life Coolant (LLC) because I had some handy... The Toyota RED is made for aluminum blocks and is SILICATE and PHOSPHATE free - this is IMPORTANT. The green stuff that was in the cooling system was "compatible with all other coolants" so it should be OK to mix with the Toyota stuff. You may want to flush with distilled water. I did not.
Pull the coolant filler neck off the bike and rotate it 90Âş so that it will allow you to pour coolant into the coolant recovery tank. Fill the recovery tank to the high mark and replace cap.
See - contents are now RED!
I burp my system via squeezing the suction hose numerous times. Be careful as you could force coolant out of raditor fill neck. Wishing all well!????
Many of the older threads that had pictures had those pictures hosted on a website called Photobucket. This website changed its rules to be a pay site and this broke all the links to the pictures. It is quite possible that the pictures in this thread were part of that fiasco.
Reactions: vtx-1300
From what I understand PhotoBucket changed their price model, and has added a "Hosted on PhotoBucket" watermark to all pictures now hosted on their site. I believe that you can pay to have the watermark removed. However, many people (like me) became so angry with PhotoBucket when they held our pictures hostage that we deleted our accounts, which also deleted our pix.
First thing is to remove the tank. Check out Bassdudes link here. Gas tank removal how to (with pics)
Is it difficult to remove the tank?
No it is not. One trick to it is related to the dash unit. So not unhook the electrical connectors that go to the dash. They are very delicate and tend to break the retaining tab. Instead, remove the entire dash unit (lower three bolts only to do this), wrap it in a small towel, and tuck it up on the handlebars. Lightly hold it in place if so desired with a small bungee cord. There is plenty of slack in the wires leading to the dash to allow this.
Then you disconnect the two hoses going to the petcock - a little gas will spill from the petcock nipple and the larger of these two hoses. Disconnect the vent hose in back right of tank. Remove seat and then remove one bolt from back of tank making sure to retain the metal spacer thru which the tank bolt passes. Then lift the back of the tank a few inches and it will then slide backwards. Slide it about 3-4 inches and it will lift right off. Of course, it will weigh less if it is near empty of gas but even full, it weighs less than 50 lbs.
Reactions: vtx-1300 and davbib
To add to Bassdudes's write up already here, ive done a short video on how to remove the tank that might be of help:
jstar61 did an amazing job at the writetup, to compliment this, i did a video of how to change the fluid and it is here:
Reactions: vtx-1300
